> What size woodruff key on shaft?
kawtoy
Geschrieben am: 30.09.2012, 18:14
Mitgliedsnummer.: 5649
Can anyone tell me what size woodruff key goes between the shaft and the magneto? Mine is missing so every time I try to start the moped the magneto moves and the timing is off. Thank you.
Geschrieben am: 30.09.2012, 18:31
http://www.ddrmoped.de/shop/katalog/scheib...r-halbmond-2x37
I think that must be the correct part .
Greets ,
Raffi
kawtoy
Geschrieben am: 03.10.2012, 03:45
Thank You. I will check and see if I can find one locally. If not I will have to order the one above.
Geschrieben am: 03.10.2012, 07:34
If you dont find one , you can make it by yourself from a flat-washer . wink.gif
Greets ,
Raffi
kawtoy
Geschrieben am: 03.10.2012, 20:48
Good idea !!
