> SR2 rebuild, no fuel to piston
fsvaasam
Geschrieben am: 23.08.2015, 11:24
Mitgliedsnummer.: 8376
Hi!
First post here. If there is need to use different carb i have used Dellorto SHA 12.12 with success. You have to build manifold for this, but its very simple. Works well with stock engine straight out of box.
I have also used SHA 14.14 carb in tuned engine, but there you have to play a little bit emulsion tube hole sizes to make it good.
